Understanding Screaming Channels: From a Detailed Analysis to Improved Attacks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IACR Transactions on Cryptographic Hardware and Embedded Systems Année : 2020
Recently, some wireless devices have been found vulnerable to a novel class of side-channel attacks, called Screaming Channels. These leaks might appear if the sensitive leaks from the processor are unintentionally broadcast by a radio transmitter placed on the same chip. Previous work focuses on identifying the root causes, and on mounting an attack at a distance considerably larger than the one achievable with conventional electromagnetic side channels, which was demonstrated in the low-noise environment of an anechoic chamber. However, a detailed understanding of the leak, attacks that take full advantage of the novel vector, and security evaluations in more practical scenarios are still missing. In this paper, we conduct a thorough experimental analysis of the peculiar properties of Screaming Channels. For example, we learn about the coexistence of intended and unintended data, the role of distance and other parameters on the strength of the leak, the distortion of the leak model, and the portability of the profiles. With such insights, we build better attacks. We profile a device connected via cable with 10000•500 traces. Then, 5 months later, we attack a different instance at 15 m in an office environment. We recover the AES-128 key with 5000•1000 traces and key enumeration up to 2 23. Leveraging spatial diversity, we mount some attacks in the presence of obstacles. As a first example of application to a real system, we show a proof-of-concept attack against the authentication method of Google Eddystone beacons. On the one side, this work lowers the bar for more realistic attacks, highlighting the importance of the novel attack vector. On the other side, it provides a broader security evaluation of the leaks, helping the defender and radio designers to evaluate risk, and the need of countermeasures.
publi-6297.pdf (4.05 Mo) Télécharger le fichier
hal-04138258 , version 1 (22-06-2023)
Paternité
Giovanni Camurati, Aurélien Francillon, François-Xavier Standaert. Understanding Screaming Channels: From a Detailed Analysis to Improved Attacks. IACR Transactions on Cryptographic Hardware and Embedded Systems, 2020, 3, ⟨10.13154/tches.v2020.i3.358-401⟩. ⟨hal-04138258⟩
Collections
EURECOM ANR
14 Consultations
44 Téléchargements
