Tweet Sentiment Extraction using Viterbi Algorithm with Transfer Learning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
Tweet sentiment extraction extracts the most significant portion of the sentence, determining whether the sentiment is positive or negative. This research aims to identify the part of tweet sentences that strikes any emotion. To reach this objective, we continue improving the Viterbi algorithm previously modified by the author to make it able to receive pre-trained model parameters. We introduce the confidence score and vector as two indicators responsible for evaluating the model internally before assessing the final results. We then present a method to fine-tune this nonparametric model. We found that the model gets highly explainable as the confidence score vector reveals precisely where the least confidence predicted states are and if the modifications approved ameliorate the confidence score or if the tuning is going in the wrong direction.
main.pdf (315.97 Ko) Télécharger le fichier
Licence : CC BY NC - Paternité - Pas d'utilisation commerciale
hal-04179874 , version 1 (10-08-2023)
Paternité - Pas d'utilisation commerciale - Pas de modification
Zied Baklouti. Tweet Sentiment Extraction using Viterbi Algorithm with Transfer Learning. 2023. ⟨hal-04179874⟩
21 Consultations
8 Téléchargements
