Using the two-way nesting technique AGRIF with MARS3D V11.2 to improve hydrodynamics and estimate environmental indicators - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Journal Articles Geoscientific Model Development Year : 2023
Abstract. In the ocean, meso / submesoscale structures and coastal processes are associated with fine scales. The simulation of such features thus requires the hydrodynamic equations to be solved at high-resolution (from a few hundred meters down to a few tens of meters). Therefore, local mesh refinement is a primary issue for regional and coastal modelling. As over structured grids, AGRIF (Adaptive Grid Refinement In Fortran) library is committed to tackle this challenge. It has been implemented in MARS3D, which is a numerical model developed by Ifremer (the French research institute for the exploitation of the sea) for coastal environmental researches and studies. The present paper describes how the dedicated implementation preserves some essential principles (mass conservation, constant preserving…) along with the induced constraints. The use and the performance of this new tool are detailed over two configurations that illustrate the wide range of scales and resolutions typically targeted by coastal applications. The first one is based on multiple high-resolution (500 m) grids that pave the coastal ocean over thousands of kilometres, allowing a continuum between the regional and coastal scales. The second application is more local and has a finer resolution (50 m). It targets a recurrent question for semi-enclosed bays: the renewal time indicator. Throughout these configurations, the paper intends at comparing the two-way nesting method with the traditional one-way approach and highlights how MARS3D-AGRIF tool proves to be an efficient way significantly improve the physical hydrodynamics and bring it biological issues.
gmd-16-1191-2023.pdf (5.93 Mo) Télécharger le fichier
Origin : Publisher files allowed on an open archive
Dates and versions
hal-04203826 , version 1 (24-03-2023)
hal-04203826 , version 2 (15-09-2023)
Attribution
Identifiers
Cite
Sébastien Petton, Valerie Garnier, Matthieu Caillaud, Laurent Debreu, Franck Dumas. Using the two-way nesting technique AGRIF with MARS3D V11.2 to improve hydrodynamics and estimate environmental indicators. Geoscientific Model Development, 2023, 16 (4), pp.1191-1211. ⟨10.5194/gmd-16-1191-2023⟩. ⟨hal-04203826v2⟩
96 View
25 Download
Share
