Using the two-way nesting technique AGRIF with MARS3D V11.2 to improvehydrodynamics and estimate environmental indicators - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Geoscientific Model Development Année : 2022
In the ocean, mesoscale or submesoscale structures and coastal processes are associated with fine scales. The simulation of such features thus requires the hydrodynamic equations to be solved at high-resolution (from a few hundred meters down to a few tens of meters). Therefore, local mesh refinement is a primary issue for regional and coastal modeling. The AGRIF(adaptive grid refinement in Fortran) library is committed to tackling sucha challenge for structured grids. It has been implemented in MARS3D (Model for Application at Regional Scale), a semi-implicit, free-surface numerical model developed by Ifremer (the French Research Institute for Exploitation of the Sea) for coastal environmental research and studies. As its time scheme uses an alternating-direction implicit (ADI) algorithm, the two-way nesting implementation differs from the one in explicit models. The present paper describes the specifics of the AGRIF introduction and how the nesting preserves some essential properties (mass, momentum and tracer conservations) along with the induced constraints (bathymetric coherence between grids and increase in computation cost). The use and the performance of this new tool are detailed over two configurations that illustrate the wide range of scales and resolutions typically targeted by coastal applications. The first one is based on multiple high-resolution(500 m) grids that pave the coastal ocean over thousands of kilometers,allowing a continuum between the regional and coastal scales. The secondapplication is more local and has a finer resolution (50 m). It targets arecurrent question for semi-enclosed bays, i.e., the renewal time indicator. Throughout these configurations, the paper intends to compare the two-way nesting method with the traditional one-way approach. It highlights how the MARS3D-AGRIF tool proves to be an efficient way to both improve the physical hydrodynamics and unravel ecological challenges.
94762.pdf (6.43 Mo) Télécharger le fichier
hal-04203826 , version 1 (24-03-2023)
hal-04203826 , version 2 (15-09-2023)
Sébastien Petton, Valérie Garnier, Matthieu Caillaud, Laurent Debreu, Franck Dumas. Using the two-way nesting technique AGRIF with MARS3D V11.2 to improvehydrodynamics and estimate environmental indicators. Geoscientific Model Development, 2022, 16 (4), pp.1191-1211. ⟨10.5194/egusphere-2022-337⟩. ⟨hal-04203826v1⟩
97 Consultations
25 Téléchargements
