Structural and Functional Annotation of the Wheat Genome - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2024
Xi Wang
  • Fonction : Auteur
  • PersonId : 1312530
Manuel Spannagl
  • Fonction : Auteur
  • PersonId : 1312531
David Swarbreck
  • Fonction : Auteur
  • PersonId : 1312532
Wheat genome sequencing has passed through major steps in a decade, starting from the sequencing of large contiguous sequences obtained from chromosome-specific BAC libraries, to reach high-quality genome assemblies of a dozen of bread wheat varieties and wild relatives. While access to an assembled genome sequence is crucial for research, the resource that is mainly used by the community is not the sequence itself, but rather the annotated features, i.e., genes and transposable elements. In this chapter, we describe the work performed to predict the repertoire of 107 k high-confidence genes and 4 million TE copies in the hexaploid wheat genome (cultivar CHINESE SPRING; IWGSC RefSeq) and the procedures established to transfer the annotation through the different releases of genome assembly. Limitations and implications for building a wheat pangenome are discussed, as well as the possibilities for future improvements of structural annotation, and opportunities offered by novel approaches for functional annotation.
978-3-031-38294-9_4.pdf (537.72 Ko) Télécharger le fichier
Origine : Publication financée par une institution
Licence : CC BY - Paternité
hal-04297331 , version 1 (21-11-2023)
Frédéric Choulet, Xi Wang, Manuel Spannagl, David Swarbreck, Hélène Rimbert, et al.. Structural and Functional Annotation of the Wheat Genome. Rudi Appels, Kellye Eversole, Catherine Feuillet, Dusti Gallagher. The Wheat Genome, Springer International Publishing, pp.51-73, 2024, Compendium of Plant Genomes, ⟨10.1007/978-3-031-38294-9_4⟩. ⟨hal-04297331⟩
795 Consultations
55 Téléchargements
