Galaxy-SynBioCAD — An Automated Pipeline for Synthetic Biology Design and Engineering - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2023
There’s a substantial number of tools released around Synthetic Biology and Metabolic Engineering- related questions and needs. This population of tools is difficult to comprehend and use together, main reasons being complexity and interoperability issues. Indeed, a high level of expertise could be required for installing codes, and execution for real life use cases could be computationally resource demanding. Plus some tools, although complementary, use different inputs and outputs which prevent easy chaining. The SynBioCAD-Galaxy portal [1] is a growing toolshed for synthetic biology, metabolic engineering, and industrial biotechnology. The tools and workflows currently shared on the portal enable one to build libraries of strains producing desired chemical targets covering an end-to-end metabolic pathway design and engineering process: from the selection of strains and targets, the design of DNA parts to be assembled, to the generation of scripts driving liquid handlers for plasmid assembly and strain transformations. Tools are made available on GitHub, anaconda.org and the Galaxy Tool Shed, opening to the greatest number access and utilization throughout the SynBio community, and significant effort has been granted for adopting FAIR principles. As a community effort helped by funded projects, the scope covered by tools is expected to expand over time. The poster will give an overview of the SynBioCAD-Galaxy portal in the context of prediction and construction of E. coli lycopene-producing pathways. The poster will open the discussion around good practices guiding releases of tools through continuous integration. A – lightweight – testing instance of SynBioCAD-Galaxy is available at https://galaxysynbiocad.org.
No file
Dates and versions
hal-04351679 , version 1 (18-12-2023)
Identifiers
  • HAL Id : hal-04351679 , version 1
Cite
Joan Hérisson, Pablo Carbonell, Jean-Loup Faulon, Thomas Duigou. Galaxy-SynBioCAD — An Automated Pipeline for Synthetic Biology Design and Engineering. Global BioFoundries Alliance Meeting 2023 (GBA2023), Sep 2023, Copenaghen, Denmark. ⟨hal-04351679⟩
49 View
0 Download
Share
