Weak Convergence of the Conditional Set-Indexed Empirical Process for Missing at Random Functional Ergodic Data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematics Année : 2024
Youssouf Souddi
Fethi Madani
  • Fonction : Auteur
This work examines the asymptotic characteristics of a conditional set-indexed empirical process composed of functional ergodic random variables with missing at random (MAR). This paper’s findings enlarge the previous advancements in functional data analysis through the use of empirical process methodologies. These results are shown under specific structural hypotheses regarding entropy and under appealing situations regarding the model. The regression operator’s asymptotic (1−α)-confidence interval is provided for 0<α<1 as an application. Additionally, we offer a classification example to demonstrate the practical importance of the methodology.
mathematics-12-00448-v2.pdf (393.78 Ko) Télécharger le fichier
hal-04427506 , version 1 (25-04-2024)
Paternité
Salim Bouzebda, Youssouf Souddi, Fethi Madani. Weak Convergence of the Conditional Set-Indexed Empirical Process for Missing at Random Functional Ergodic Data. Mathematics , 2024, 12 (3), pp.448. ⟨10.3390/math12030448⟩. ⟨hal-04427506⟩
20 Consultations
0 Téléchargements
