Data-Driven Methodology for the Investigation of Riding Dynamics: A Motorcycle Case Study - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Intelligent Transportation Systems Année : 2023
Powered-Two-Wheelers (PTW) riders’ fatalities are prevalent on bends outside built-up areas due to the complexity and instability of their vehicles: countermeasures require a better understanding of the rider-PTW interaction. Analysing riding data is effective but becomes challenging when using extensive datasets; segmenting the riding data would help identify events of interest, isolate specific manoeuvres and describe the riding session. Manual segmentation would be time-consuming and subjective; automation would be beneficial. This work proposed an automatic, unsupervised tool for segmenting and clustering signals acquired during a riding session for studying motorcycle lateral dynamics in-depth. The method only requires measuring the motorcycle roll angle. An expert rider completed a closed route using an instrumented motorcycle; the algorithm divided the time series into segments categorised into clusters relative to specific riding conditions. Analysing the segmented trial revealed the effectiveness and usefulness of the approach. Then, a corner entry manoeuvre was investigated in-depth to observe each segment’s properties. The method associated each riding primitive to a cluster and described each manoeuvre through the segments’ succession. The clusters were unambiguous and easy to interpret thanks to their dynamics-based nature and minimal overlap. The algorithm identified the differences between the three corner entry manoeuvres in the trial. The segmentation simplified the in-depth corner entry analysis and allowed early detection of the manoeuvre start. The proposed tool can aid research on motorcycle dynamics, PTW-rider interaction, and riding preferences in bends. The segmented time series could be employed for rider training and pre-crash fall dynamics reconstruction
Data-Driven_Methodology_for_the_Investigation_of_Riding_Dynamics_A_Motorcycle_Case_Study.pdf (1.84 Mo) Télécharger le fichier
Origine : Publication financée par une institution
Licence : CC BY - Paternité
hal-04451221 , version 1 (19-04-2024)
Mirco Bartolozzi, Abderrahmane Boubezoul, Samir Bouaziz, Giovanni Savino, Stéphane Espie. Data-Driven Methodology for the Investigation of Riding Dynamics: A Motorcycle Case Study. IEEE Transactions on Intelligent Transportation Systems, 2023, 24 (9), pp.10224-10237. ⟨10.1109/TITS.2023.3271790⟩. ⟨hal-04451221⟩
18 Consultations
0 Téléchargements
