Insights into the performance and mechanism of Cr(VI) and U(VI) removal in water using innovative cross-linked chitosan adsorbent - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Environmental Chemical Engineering Année : 2024
The primary aim of this work is to test a novel adsorbent prepared by cross-linking of tetrafluoroterephthalonitrile with chitosan (CS-TFT) for the removal of Cr(VI) and U(VI). The CS-TFT is stable until 250 °C and possesses amino functional groups due to the presence of CS that remain intact even after the cross-linking reaction, thus being a benefit for adsorption properties; while the TFT brought roughness to CS-TFT that keeps its high porosity. The adsorption efficiency of CS-TFT is evaluated in the batch experiment of Cr(VI) and U(VI) adsorption along with the effect of different experimental parameters (pH, time, temperature, initial concentrations, and co-existing inorganic cations). The maximum adsorption capacity of CS-TFT for adsorption of Cr(VI) and U(VI) was 265.96 mg·g-1 at pH = 3 and 346.06 mg·g-1 at pH = 5, respectively, at 298 K and the corresponding partition coefficients were 12,454 and 6181 mg g-1 mM-1, respectively. The kinetics of the adsorption process is identified as a pseudo-second-order model and the Langmuir isotherm model is considered. The CS-TFT shows satisfactory reusability since it can be used after 6 cycles of regeneration with a removal efficiency of Cr(VI) and U(VI) higher than 90 %. The adsorption mechanism is also proposed based on investigation of CS-TFT by FTIR, XPS and SEM-EDS before and after adsorption. The results show that hydroxy (–OH) and amino (–NH2) groups play a key role in the chemical adsorption. All these findings suggest that CS-TFT could be a promising adsorbent for wastewaters treatment.
Fichier sous embargo
0 1 9
Année Mois Jours
Avant la publication
lundi 17 juin 2024
0 1 9
Année Mois Jours
lundi 17 juin 2024
lundi 17 juin 2024
Connectez-vous pour demander l'accès au fichier
hal-04467421 , version 1 (25-04-2024)
Paternité - Pas d'utilisation commerciale
Peng Cheng, Zhiyang Wei, Yara Arbid, Tengfei Fu, Xiaowei Liu, et al.. Insights into the performance and mechanism of Cr(VI) and U(VI) removal in water using innovative cross-linked chitosan adsorbent. Journal of Environmental Chemical Engineering, 2024, 12 (1), pp.111731. ⟨10.1016/j.jece.2023.111731⟩. ⟨hal-04467421⟩
16 Consultations
0 Téléchargements
