Supervised diagnosis prediction from cortical sulci: toward the discovery of neurodevelopmental biomarkers in mental disorders - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2024
Recent advances in machine learning applied to structural magnetic resonance imaging (sMRI) may highlight abnormalities in brain anatomy associated with mental disorders. These disorders are multifactorial, resulting from a complex combination of neurodevelopmental and environmental factors. In particular, such factors are present in cortical sulci, whose shapes are determined very early in brain development and are a valuable proxy for capturing specifically the neurodevelopmental contribution of brain anatomy. This paper explores whether the shapes of cortical sulci can be used for diagnosis prediction using deep learning models. These models are applied to three mental disorders (autism spectrum disorder, bipolar disorder, and schizophrenia) in large multicentric datasets. We demonstrate that the neurodevelopmental underpinnings of these disorders can be captured withsMRI. Finally, we show the potential of visual explanations of models’ decisions in discovering biomarkers for mental disorders.
ISBI_2024_Pierre_Auriau.pdf (2.83 Mo) Télécharger le fichier
hal-04494994 , version 1 (11-03-2024)
  • HAL Id : hal-04494994 , version 1
Pierre Auriau, Antoine Grigis, Benoit Dufumier, Robin Louiset, Joel Chavas, et al.. Supervised diagnosis prediction from cortical sulci: toward the discovery of neurodevelopmental biomarkers in mental disorders. 21st IEEE International Symposium on Biomedical Imaging (ISBI 2024), IEEE, May 2024, Athènes, Greece. ⟨hal-04494994⟩
93 Consultations
13 Téléchargements
