Assembling algorithm for Green's tensors and absorbing boundary conditions for Galbrun's equation in radial symmetry - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail (Preprint/Prepublication) Année : 2024
Solar oscillations can be modeled by Galbrun's equation which describes Lagrangian wave displacement in a self-gravitating stratified medium. For spherically symmetric backgrounds, we construct an algorithm to compute efficiently and accurately the coefficients of the Green's tensor of the time-harmonic equation in vector spherical harmonic basis. With only two resolutions, our algorithm provides values of the kernels for all heights of source and receiver, and prescribes analytically the singularities of the kernels. We also derive absorbing boundary conditions (ABC) to model wave propagation in the atmosphere above the cut-off frequency. The construction of ABC, which contains varying gravity terms, is rendered difficult by the complex behavior of the solar potential in low atmosphere and for frequencies below the Lamb frequency. We carry out extensive numerical investigations to compare and evaluate the efficiency of the ABCs in capturing outgoing solutions. Finally, as an application towards helioseismology, we compute synthetic solar power spectra that contain pressure modes as well as internal-gravity (g-) and surface-gravity (f-) ridges which are missing in simpler approximations of the wave equation. For purpose of validation, the location of the ridges in the synthetic power spectra are compared with observed solar modes.
hal-04503374 , version 1 (13-03-2024)
Ha Pham, Florian Faucher, Damien Fournier, Hélène Barucq, Laurent Gizon. Assembling algorithm for Green's tensors and absorbing boundary conditions for Galbrun's equation in radial symmetry. 2024. ⟨hal-04503374⟩
1 Consultations
0 Téléchargements
