Measurement-based run-to-run optimization of a batch reaction-distillation system - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Aided Chemical Engineering Année : 2005
Measurement-based optimization schemes have been developed to deal with uncertainty and process variations. One of the methods therein, labeled NCO tracking, relies on appropriate parameterization of the input profiles and adjusts the corresponding input parameters using measurements so as to satisfy the necessary conditions of optimality (NCO). The applicability of NCO-tracking schemes has been demonstrated on several academic-size examples. The goal of this paper is to show that it can be applied with similar ease to more complex real-life systems. Run-to-run optimization of a batch reaction-separation system with propylene glycol is used for illustration
Marchetti_2005.pdf (436.89 Ko) Télécharger le fichier
hal-04512887 , version 1 (29-03-2024)
A. Marchetti, B. Srinivasan, D. Bonvin, Sébastien Elgue, Laurent Prat, et al.. Measurement-based run-to-run optimization of a batch reaction-distillation system. Computer Aided Chemical Engineering, 2005, Computer Aided Chemical Engineering, 20, pp.1417-1422. ⟨10.1016/S1570-7946(05)80078-1⟩. ⟨hal-04512887⟩
1 Consultations
0 Téléchargements
