Model-free based pitch control of a wind turbine blade section: aerodynamic simulation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2024
This work addresses the problem of controlling the local aerodynamic lift of a wind turbine blade taking into account disturbances caused by turbulent perturbations at the blade scale. This work deals with the study of a model-free based control algorithm implemented in the high fidelity simulated environment ISIS-CFD, where the controller acts at the level of the blade section to track the lift to a desired reference. Numerical experiments have been conducted in order to highlight some properties of the aerodynamic closed-loop system under several operating conditions.
ECC24_pitch_blade_control.pdf (560.19 Ko) Télécharger le fichier
hal-04520407 , version 1 (25-03-2024)
  • HAL Id : hal-04520407 , version 1
Loïc Michel, Emmanuel Guilmineau, Caroline Braud, Franck Plestan, Jean Pierre Barbot. Model-free based pitch control of a wind turbine blade section: aerodynamic simulation. European Control Conference 2024, Jun 2024, Stockholm (Suède), Sweden. ⟨hal-04520407⟩
223 Consultations
7 Téléchargements
