FastECPP over MPI - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2024
FastECPP over MPI
Andreas Enge
The FastECPP algorithm is currently the fastest approach to prove the primality of general numbers, and has the additional benefit of creating certificates that can be checked independently and with a lower complexity. This article shows how by parallelising over a linear number of cores, its quartic time complexity becomes a cubic wallclock time complexity; and it presents the algorithmic choices of the FastECPP implementation in the author's \cm\ software \\ \centerline {\url {https://www.multiprecision.org/cm/}} which has been written with massive parallelisation over MPI in mind and used to establish a new primality record, for the ``repunit'' $(10^{86453} - 1) / 9$.
ecppmpi.pdf (167.7 Ko) Télécharger le fichier
Licence : CC BY SA - Paternité - Partage selon les Conditions Initiales
hal-04522492 , version 1 (08-04-2024)
hal-04522492 , version 2 (01-05-2024)
  • HAL Id : hal-04522492 , version 1
Andreas Enge. FastECPP over MPI. 2024. ⟨hal-04522492v1⟩
11 Consultations
3 Téléchargements
