EXPERIMENTAL AND NUMERICAL STUDIES OF MOISTURE AND TOLUENE BUFFERING CAPACITY OF HEMP CONCRETE - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2024
ÉTUDES EXPÉRIMENTALES ET NUMÉRIQUES DE LA CAPACITÉ TAMPON HYGRIQUE ET DU TOLUÈNE DU BÉTON DE CHANVRE
Hemp lime concrete (HLC) is an environment-friendly material increasingly used in building construction. Many studies have focused on the moisture buffer capacity of HLC, but its pollutant buffering capacity remains unknown. To address this research gap, the potential for moisture and toluene buffering capacity of hemp concrete is presented in this article. The sorption capacity toward toluene (TOL), a typical indoor volatile organic compound (VOC), of HLC has been measured and investigated with a 50 L environmental chamber at 23°C and a relative humidity of 50%. Moisture buffering capacity of HLC has been determined according to the Nordtest protocol. The experimental data have been used to evaluate the model parameters of the CHAMPS-bio model (Coupled Heat, Air, Moisture and Pollutant Simulation transport model dedicated to Bio-based building materials) that assesses VOC transfers and hygrothermal behavior of building materials under dynamic conditions. The results are innovative and new for hemp concrete, and evidence that this bio-based material can mitigate the indoor toluene concentration and regulate indoor relative humidity thanks to its buffering capacity.
ART ID191 Moisture and VOC behavior of hemp concrete ICCM2024 -VF.pdf (1.31 Mo) Télécharger le fichier
hal-04528980 , version 1 (02-04-2024)
  • HAL Id : hal-04528980 , version 1
Anh Dung Tran Le, Fathia Dahir Igue, Bing Beverly, Jianshun S. Zhang, Zhenlei Liu, et al.. EXPERIMENTAL AND NUMERICAL STUDIES OF MOISTURE AND TOLUENE BUFFERING CAPACITY OF HEMP CONCRETE. 12th ACI/RILEM International Conference on Cementitious Materials and Alternative Binders for Sustainable Concrete (ICCM 2024), Jun 2024, Toulouse, France. ⟨hal-04528980⟩
13 Consultations
6 Téléchargements
