Determination of the maximum bioaccumulation capacity of various metals in leaves of two Tillandsia species - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Environmental Science and Pollution Research Année : 2024
Damien Herfurth
Roland Molinié
Tillandsia species are plants from the Bromeliaceae family which display biomonitoring capacities in both active and passive modes. The bioaccumulation potential of Tillandsia aeranthos (Loisiel.) Desf. and Tillandsia bergeri Mez acclimated to Southern/Mediterranean Europe has never been studied. More generally, few studies have detailed the maximum accumulation potential of Tillandsia leaves through controlled experiments. The aim of this study is to evaluate the maximum accumulation values of seven metals (Co, Cu, Mn, Ni, Pb, Pt, and Zn) in T. aeranthos and T. bergeri leaves. Plants were immersed in different mono elemental metallic solutions of Co (II), Cu (II), Mn (II), Ni (II), Pb (II), Pt (IV), and Zn (II) ions at different concentrations. In addition, cocktail solutions of these seven metals at different concentrations were prepared to study the main differences and the potential selectivity between metals. After exposure, the content of these metals in the leaves were measured by inductively coupled plasma-optical emission spectrometry. Data sets were evaluated by a fitted regression hyperbola model and principal component analysis, maximum metal loading capacity, and thermodynamic affinity constant were determined. The results showed important differences between the two species, with T. bergeri demonstrating higher capacity and affinity for metals than T. aeranthos. Furthermore, between the seven metals, Pb and Ni showed higher enrichment factors (EF). T. bergeri might be a better bioaccumulator than T. aeranthos with marked selectivity for Pb and Ni, metals of concern in air quality biomonitoring.
Fichier sous embargo
0 5 0
Année Mois Jours
Avant la publication
dimanche 6 octobre 2024
Connectez-vous pour demander l'accès au fichier
hal-04535649 , version 1 (26-04-2024)
Alexandre Gonzalez, Zohra Benfodda, David Bénimélis, Damien Bourgeois, Damien Herfurth, et al.. Determination of the maximum bioaccumulation capacity of various metals in leaves of two Tillandsia species. Environmental Science and Pollution Research, In press, ⟨10.1007/s11356-024-33183-3⟩. ⟨hal-04535649⟩
0 Consultations
0 Téléchargements
