Influence of a hydroelectric dam on fish mercury contamination along the Sinnamary River (French Guiana) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Ecotoxicology and Environmental Safety Année : 2024
The Petit Saut hydroelectric dam and the upstream and downstream areas of the Sinnamary River in French Guiana (Amazon basin) have been studied from 1993 to 2020. The nearly thirty-years-long study of the monitoring of total mercury concentration in fish and the physicochemical survey of the environment made it possible to demonstrate the impact of the flooding of the forest and the role of the hydroelectric dam on the methylation of mercury. Results show that the physicochemical modifications generated by the construction of the dam led to a significant production of methylmercury (MeHg) in the anoxic part of the reservoir and downstream of the river leading to a strong spatio-temporal impact of the dam. Seven species of fishes are studied and their mercury concentrations vary according to many parameters: fish diet, position in the water column, site, lake oxycline level and time.
1-s2.0-S0147651323012757-main.pdf (5.78 Mo) Télécharger le fichier
hal-04546194 , version 1 (17-04-2024)
Paternité - Pas d'utilisation commerciale - Pas de modification
Regine Maury-Brachet, Emilie Dassie, Alexia Legeay, Patrice Gonzalez, Agnes Feurtet-Mazel, et al.. Influence of a hydroelectric dam on fish mercury contamination along the Sinnamary River (French Guiana). Ecotoxicology and Environmental Safety, 2024, 269, pp.115771. ⟨10.1016/j.ecoenv.2023.115771⟩. ⟨hal-04546194⟩
Collections
INSU EPHE CNRS PSL
0 Consultations
0 Téléchargements
