Assessing the Hydropower Potential Using Hydrological Models and Geospatial Tools in the White Bandama Watershed (Côte d'Ivoire, West Africa) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Frontiers in Water Année : 2022
An assessment of hydropower potential at the watershed scale was conducted at the White Bandama Watershed (WBW) in Côte d'Ivoire (West Africa). The method used involves the application of a hydrological model [Soil and Water Assessment Tool (SWAT)] coupled with a Quantum Geographic Information System (QGIS), denoted as QSWAT, to assess the water resource availability and hydropower potential of streams and determine potential hydropower sites for future hydropower development in the watershed. Geospatial data about the topography, soil types, land use/land cover, weather, and discharge were considered in hydrological and hydro-geomorphological characterization of the watershed. Streamflow and climate data-enabled model operation and simulation of the hydrology of the watershed. The model performance and robustness were confirmed with the p-factor, r-factor , coefficient of determination R 2 , and Nash–Sutcliffe (NS) efficiency coefficient. The hydropower potential of streams was evaluated by considering the simulated streamflow and water head. A total of 22 future hydropower sites was identified, geolocated, and classified with an estimated total production capacity of 538.56 MW.
frwa-04-844934.pdf (3.45 Mo) Télécharger le fichier
hal-04548650 , version 1 (16-04-2024)
Claude Alain Kouadio, Kouakou Lazare Kouassi, Arona Diedhiou, Salomon Obahoundje, Ernest Amoussou, et al.. Assessing the Hydropower Potential Using Hydrological Models and Geospatial Tools in the White Bandama Watershed (Côte d'Ivoire, West Africa). Frontiers in Water, 2022, 4, pp.844934. ⟨10.3389/frwa.2022.844934⟩. ⟨hal-04548650⟩
0 Consultations
0 Téléchargements
