Exploration on the combustion chemistry of p-xylene: A comprehensive study over wide conditions and comparison among C8H10 isomers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Combustion and Flame Année : 2024
Pyrolysis and oxidation of p-xylene over wide conditions were studied in this work in order to provide a comprehensive insight into the combustion chemistry of p-xylene. Concerning this goal, the pyrolysis of p-xylene was investigated in a flow reactor at pressures from 0.04 to 1 atm over the temperature range of 1000-1600 K. Key radicals, isomers and PAH products including three xylyl isomers, benzyl, xylylene isomers, styrene, benzene, fulvene, indene, naphthalene and phenanthrene, were identified and quantified using synchrotron vacuum ultraviolet photoionization mass spectrometry. The oxidation of p-xylene was studied in a jet-stirred reactor at 10 atm, 800-1300 K and equivalence ratios of 0.5-2.0 with a residence time of 0.5 s. Oxidation products were quantified by using gas chromatography combined with mass spectrometry and Fourier transform infrared spectrometry. A kinetic model for p-xylene combustion over wide conditions was developed based on our previously proposed p-xylene oxidation model and validated against the new experimental measurements in this work and literature reported experimental data, including flow reactor oxidation, laminar premixed flame, ignition delay time and laminar burning velocity. In the flow reactor pyrolysis, p-xylene mainly undergoes unimolecular decomposition to yield p-xylyl, which mainly suffers the H-loss reaction to form p-xylylene and isomerization reaction to form o-xylyl. The resonantly stabilized fulvenallenyl and benzyl radicals play an important role in the formation of bicyclic and tricyclic PAHs including indene, naphthalene, and phenanthrene. In the JSR oxidation, p-xylene is predominantly consumed via H-abstraction by oxygenated radicals such as OH, O, and HO2 forming p-xylyl, which can be oxidized by HO2 and eventually converted to p-methylbenzaldehyde. As the most abundantly produced oxygenated aromatics, further consumption of p-methylbenzaldehyde results in the formation of other observed oxygenated aromatics such as cresol, benzofuran, and benzaldehyde. The combustion chemistry of three C8H10 isomers, i.e., p-xylene, o-xylene, and ethylbenzene, were also compared in terms of pyrolysis and oxidation fuel reactivity, and PAHs formation and growth, showing remarkable fuel isomeric effects.
p-Xylene CNF.pdf (1.93 Mo) Télécharger le fichier
hal-04549079 , version 1 (17-04-2024)
Copyright (Tous droits réservés)
Yuwen Deng, Wenhao Yuan, Sandro Gaïl, Wei Li, Long Zhao, et al.. Exploration on the combustion chemistry of p-xylene: A comprehensive study over wide conditions and comparison among C8H10 isomers. Combustion and Flame, 2024, 262, pp.113377. ⟨10.1016/j.combustflame.2024.113377⟩. ⟨hal-04549079⟩
0 Consultations
0 Téléchargements
