Joint Annotation of Morphology and Syntax in Dependency Treebanks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2024
Bruno Guillaume
Kirian Guiller
  • Fonction : Auteur
  • PersonId : 1375903
Sylvain Kahane
In this paper, we compare different ways to annotate both syntactic and morphological relations in a dependency treebank. We propose new formats we call mSUD and mUD, compatible with the Universal Dependencies (UD) schema for syntactic treebanks. We emphasize on mSUD rather than mUD, the former being based on distributional criteria for the choice of the head of any combination, which allows us to clearly encode the internal structure of a word, that is, the derivational path. We investigate different problems posed by a morph-based annotation, concerning tokenization, choice of the head of a morph combination, relations between morphs, additional features needed, such as the token type differentiating roots and derivational and inflectional affixes. We show how our annotation schema can be applied to different languages from polysynthetic languages such as Yupik to isolating languages such as Chinese.
mSUD.pdf (673.65 Ko) Télécharger le fichier
hal-04550108 , version 1 (17-04-2024)
Paternité
  • HAL Id : hal-04550108 , version 1
Bruno Guillaume, Kim Gerdes, Kirian Guiller, Sylvain Kahane, Yixuan Li. Joint Annotation of Morphology and Syntax in Dependency Treebanks. The 2024 Joint International Conference on Computational Linguistics, Language Resources and Evaluation (LREC-COLING), May 2024, Turino, Italy. ⟨hal-04550108⟩
6 Consultations
0 Téléchargements
