Walking kinematics in the polymorphic seed harvester ant Messor barbarus: influence of body size and load carriage - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Experimental Biology Année : 2019
Ants are famous in the animal kingdom for their amazing load carriage performances. Yet, the mechanisms that allow these insects to maintain their stability when carrying heavy loads have been poorly investigated. Here we present a study of the kinematics of unloaded and loaded locomotion in the polymorphic seed-harvesting ant Messor barbarus. In this species big ants have larger heads relative to their size than small ants. Hence, their center of mass is shifted forward, and the more so when they are carrying a load in their mandibles. We tested the hypothesis that this could lead to big ants being less statically stable than small ants, thus explaining their lower load carriage performances. When walking unloaded we found that big ants were indeed less statically stable than small ants but that they were nonetheless able to adjust their stepping pattern to partly compensate for this instability. When ants were walking loaded on the other hand, there was no evidence of different locomotor behaviors in individuals of different sizes. Loaded ants, whatever their size, move too slowly to maintain their balance through dynamic stability. Rather, they seem to do so by clinging to the ground with their hind legs during part of a stride. We show through a straightforward model that allometric relationships have a minor role in explaining the differences in load carriage performances between big ants and small ants and that a simple scale effect is sufficient to explain these differences.
Mérienne-Jeb 2019 -HAL.pdf (1.74 Mo) Télécharger le fichier
hal-04550407 , version 1 (17-04-2024)
Paternité - Pas d'utilisation commerciale - Pas de modification
Hugo Merienne, Gérard Latil, Pierre Moretto, Vincent Fourcassié. Walking kinematics in the polymorphic seed harvester ant Messor barbarus: influence of body size and load carriage. Journal of Experimental Biology, 2019, 223 (3), pp.jeb205690. ⟨10.1242/jeb.205690⟩. ⟨hal-04550407⟩
0 Consultations
0 Téléchargements
