An auditory perspective on phonological development in infancy - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Frontiers in Psychology Année : 2024
Introduction The auditory system encodes the phonetic features of languages by processing spectro-temporal modulations in speech, which can be described at two time scales: relatively slow amplitude variations over time (AM, further distinguished into the slowest <8–16 Hz and faster components 16–500 Hz), and frequency modulations (FM, oscillating at higher rates about 600–10 kHz). While adults require only the slowest AM cues to identify and discriminate speech sounds, infants have been shown to also require faster AM cues (>8–16 Hz) for similar tasks. Methods Using an observer-based psychophysical method, this study measured the ability of typical-hearing 6-month-olds, 10-month-olds, and adults to detect a change in the vowel or consonant features of consonant-vowel syllables when temporal modulations are selectively degraded. Two acoustically degraded conditions were designed, replacing FM cues with pure tones in 32 frequency bands, and then extracting AM cues in each frequency band with two different low-pass cut- off frequencies: (1) half the bandwidth (Fast AM condition), (2) <8 Hz (Slow AM condition). Results In the Fast AM condition, results show that with reduced FM cues, 85% of 6-month-olds, 72.5% of 10-month-olds, and 100% of adults successfully categorize phonemes. Among participants who passed the Fast AM condition, 67% of 6-month-olds, 75% of 10-month-olds, and 95% of adults passed the Slow AM condition. Furthermore, across the three age groups, the proportion of participants able to detect phonetic category change did not differ between the vowel and consonant conditions. However, age-related differences were observed for vowel categorization: while the 6- and 10-month-old groups did not differ from one another, they both independently differed from adults. Moreover, for consonant categorization, 10-month-olds were more impacted by acoustic temporal degradation compared to 6-month-olds, and showed a greater decline in detection success rates between the Fast AM and Slow AM conditions. Discussion The degradation of FM and faster AM cues (>8 Hz) appears to strongly affect consonant processing at 10 months of age. These findings suggest that between 6 and 10 months, infants show different developmental trajectories in the perceptual weight of speech temporal acoustic cues for vowel and consonant processing, possibly linked to phonological attunement.
Hegde et al 2024 frontiers.pdf (1.06 Mo) Télécharger le fichier
hal-04550458 , version 1 (17-04-2024)
Monica Hegde, Thierry Nazzi, Laurianne Cabrera. An auditory perspective on phonological development in infancy. Frontiers in Psychology, 2024, 14, pp.1321311. ⟨10.3389/fpsyg.2023.1321311⟩. ⟨hal-04550458⟩
0 Consultations
0 Téléchargements
