Superior Ignition and Combustion Performance of TiB2 Integrated Al/CuO Nanothermites - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2024
Nanothermites, composed of a fuel and an oxidizer, belong to a class of energetic materials that release energy as a result of a redox reaction. Reactive multilayer films, also referred to as nanolaminates, have been widely utilized as a prevalent technology in this field. Al stands out as a prominent fuel choice due to its cost-effectiveness, abundance and high energy density. Constrained by its high ignition point, there has been a strong interest in modifying Al-based thermites through chemical alterations. This work explored the influence of nano-TiB2 addition to CuO/Al and examined the effects on the overall energetic properties.
GEET2024-Final-Vidushi Singh.pdf (284.42 Ko) Télécharger le fichier
hal-04551042 , version 1 (18-04-2024)
  • HAL Id : hal-04551042 , version 1
Vidushi Singh. Superior Ignition and Combustion Performance of TiB2 Integrated Al/CuO Nanothermites. GEET Congrés 2024, Ecole Doctorale de Génie Electrique, Electronique, Télécommunications et Santé, Jun 2024, Toulouse, France. ⟨hal-04551042⟩
1 Consultations
0 Téléchargements
