ARBRES Kenstur: a Breton-French Parallel Corpus Rooted in Field Linguistics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2024
ARBRES is an ongoing project of open science implemented as a platform (“wikigrammar”) documenting both the Breton language itself and the state of research and engineering work in linguistics and NLP. Along its nearly 15 years of operation, it has aggregated a wealth of linguistic data in the form of interlinear glosses with translations illustrating lexical items, grammatical features, dialectal variations… While these glosses were primarily meant for human consumption, their volume and the regular format imposed by the wiki engine used for the website also make them suitable for machine processing. ARBRES Kenstur is a new parallel corpus derived from the glosses in ARBRES, including about 5k phrases and sentences in Breton along with translations in standard French. The nature of the original data — sourced from field linguistic inquiries meant to document the structure of Breton — leads to a resource that is mechanically more concerned with the internal variations of the language and rare phenomena than typical parallel corpora. Preliminaries experiments in using this corpus show that it can help improve machine translation for Breton, demonstrating that sourcing data from field linguistic documentation can be a way to help provide NLP tools for minority and low-resource languages.
ARBRES_LREC_2024.pdf (64.39 Ko) Télécharger le fichier
hal-04551941 , version 1 (18-04-2024)
Paternité - Partage selon les Conditions Initiales
  • HAL Id : hal-04551941 , version 1
Loïc Grobol, Mélanie Jouitteau. ARBRES Kenstur: a Breton-French Parallel Corpus Rooted in Field Linguistics. LREC-COLING 2024 - The 2024 Joint International Conference on Computational Linguistics, Language Resources and Evaluation, ELRA Language Resources Association Language Resources Association; International Committee on Computational Linguistics, May 2024, Torino, Italy. ⟨hal-04551941⟩
0 Consultations
0 Téléchargements
