Experimental Validation of Sensitivity-Aware Trajectory Planning for a Quadrotor UAV Under Parametric Uncertainty - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2024
In this work, we provide an experimental vali- dation of the recent concepts of closed-loop state and input sensitivity in the context of robust flight control for a quadrotor (UAV) equipped with the popular PX4 controller. Our objective is to experimentally assess how the optimization of the reference trajectory w.r.t. these sensitivity metrics can improve the closed- loop system performance against model uncertainties commonly affecting the quadrotor systems. To accomplish this, we present a series of experiments designed to validate our optimization approach on two distinct trajectories, with the primary aim of assessing its precision in guiding the quadrotor through the center of a window at relatively high speeds. This approach provides some interesting insights for increasing the closed- loop robustness of the robot state and inputs against physical parametric uncertainties that may degrade the system’s perfor- mance.
ICUAS_2024_Sens_Exp (1).pdf (3.64 Mo) Télécharger le fichier
hal-04553932 , version 1 (21-04-2024)
Paternité
  • HAL Id : hal-04553932 , version 1
Ali Srour, Salvatore Marcellini, Tommaso Belvedere, Marco Cognetti, Antonio Franchi, et al.. Experimental Validation of Sensitivity-Aware Trajectory Planning for a Quadrotor UAV Under Parametric Uncertainty. ICUAS 2024 - International Conference on Unmanned Aircraft Systems, Jun 2024, Chania Crete, Greece. pp.1-7. ⟨hal-04553932⟩
0 Consultations
0 Téléchargements
