Lithium and cobalt extraction from LiCoO2 assisted by p(VBPDA-co-FDA) copolymers in supercritical CO2 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Waste Management Année : 2024
Andrea Zitolo
  • Fonction : Auteur
Supercritical CO2 (scCO2) extraction assisted by complexing copolymers is a promising process to recover valuable metals from lithium-ion batteries (LIBs). CO2, in addition to being non-toxic, abundant and non-flammable, allows an easy separation of metal-complexes from the extraction medium by depressurization, limiting the wastewater production. In this study, CO2-philic gradient copolymers bearing phosphonic diacid complexing groups (poly(vinylbenzylphosphonic diacid-co-1,1,2,2-tetrahydroperfluorodecylacrylate), p(VBPDA-co-FDA)) were synthesized for the extraction of lithium and cobalt from LiCoO2 cathode material. Notably, the copolymer was able to play the triple role of leaching agent, complexing agent and surfactant. The proof of concept for leaching, complexation and extraction was achieved, using two different extraction systems. A first extraction system used aqueous hydrogen peroxide as reducing agent while it was replaced by ethanol in the second extraction system. The scCO2 extraction conditions such as extraction time, temperature, functional copolymer concentration, and the presence of additives were optimized to improve the metals extraction from LiCoO2 cathode material, leading to an extraction efficiency of Li and Co up to ca. 75 % at 60 °C and 250 bar.
Fichier sous embargo
0 5 7
Année Mois Jours
Avant la publication
dimanche 20 octobre 2024
0 5 7
Année Mois Jours
Connectez-vous pour demander l'accès au fichier
hal-04554995 , version 1 (25-04-2024)
Joshua Vauloup, Cécile Bouilhac, Moulay‐tahar Sougrati, Lorenzo Stievano, Nicolas Coppey, et al.. Lithium and cobalt extraction from LiCoO2 assisted by p(VBPDA-co-FDA) copolymers in supercritical CO2. Waste Management, 2024, 181, pp.199-210. ⟨10.1016/j.wasman.2024.03.018⟩. ⟨hal-04554995⟩
0 Consultations
0 Téléchargements
