Ground Reaction Forces and Moments Estimation from Embedded Insoles using Machine Learning Regression Models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2024
The objective of this paper was to assess the possibility of estimating 6D ground reaction forces and moments during continuous double supports exercises using instrumented force insoles. Thanks to machine learning regression, the study evaluated the performance of an embedded solution in comparison to a reference laboratory grade force plate. While insoles were validated in the context of gait, few studies investigated their accuracy in estimating ground reaction forces and moments for rehabilitation exercises with both feet on the ground. Thus, popular ankle and hip strategies, squat and hula hoop exercises were investigated. The estimation accuracy was reported with a low average error of 1.6 ± 0.3% of the body weight and 1.2 ± 0.3% of the body weight times the body height along with a moderate correlation when using solely features extracted from insoles measurements. These results demonstrated the possibility of using embedded solutions to estimate the full ground reaction wrench if the learning process was applied for each specific task separately.
Fichier sous embargo
0 0 13
Année Mois Jours
Avant la publication
vendredi 24 mai 2024
Connectez-vous pour demander l'accès au fichier
hal-04557250 , version 1 (24-04-2024)
  • HAL Id : hal-04557250 , version 1
Maxime Sabbah, Raphael Dumas, Zoe Pomarat, Lucas Robinet, Mohamed Adjel, et al.. Ground Reaction Forces and Moments Estimation from Embedded Insoles using Machine Learning Regression Models. IEEE RAS EMBS 10th International Conference on Biomedical Robotics and Biomechatronics (BioRob 2024), Sep 2024, Heidelberg (Germany), France. ⟨hal-04557250⟩
0 Consultations
0 Téléchargements
