On interactivity in fuzzy controllers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Bulletin pour les sous-ensembles flous et leurs applications Année : 1982
We sketch the usual construction of a fuzzy logic controller out of a family of control rules and consider the problem if such a controller works in accordance with these rules. This is not always the case. We solve the problem of getting a necessary and sufficient condition for the controller rules to generate a controller which works in accordance with these rules, and we find additionally that every controller can be generated by such a special set of control rules.
BUSEFAL_12_GOTTWALD_scanIRIT.pdf (122.54 Ko) Télécharger le fichier
hal-04558859 , version 1 (25-04-2024)
  • HAL Id : hal-04558859 , version 1
Siegfried Gottwald, Ernest Czoglala. On interactivity in fuzzy controllers. Bulletin pour les sous-ensembles flous et leurs applications, 1982, 12, pp.72--76. ⟨hal-04558859⟩
0 Consultations
0 Téléchargements
