Wastewater Surveillance in Europe for Non-Polio Enteroviruses and Beyond - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue (Article De Synthèse) Microorganisms Année : 2023
Laura Bubba
Soile Blomqvist
  • Fonction : Auteur
  • PersonId : 1378587
Javier Martin
Alexander G Shaw
Lasse D Rasmussen
Anda Baicus
Heli Harvala
  • Fonction : Auteur
  • PersonId : 1378594
Wastewater surveillance (WWS) was developed in the early 1960s for the detection of poliovirus (PV) circulation in the population. It has been used to monitor several pathogens, including non-polio enteroviruses (NPEVs), which are increasingly recognised as causes of morbidity in children. However, when applying WWS to a new pathogen, it is important to consider the purpose of such a study as well as the suitability of the chosen methodology. With this purpose, the European Non-Polio Enterovirus Network (ENPEN) organised an expert webinar to discuss its history, methods, and applications; its evolution from a culture-based method to molecular detection; and future implementation of next generation sequencing (NGS). The first simulation experiments with PV calculated that a 400 mL sewage sample is sufficient for the detection of viral particles if 1:10,000 people excrete poliovirus in a population of 700,000 people. If the method is applied correctly, several NPEV types are detected. Despite culture-based methods remaining the gold standard for WWS, direct methods followed by molecular-based and sequence-based assays have been developed, not only for enterovirus but for several pathogens. Along with case-based sentinel and/or syndromic surveillance, WWS for NPEV and other pathogens represents an inexpensive, flexible, anonymised, reliable, population-based tool for monitoring outbreaks and the (re)emergence of these virus types/strains within the general population.
microorganisms-11-02496-v2.pdf (944.58 Ko) Télécharger le fichier
hal-04560128 , version 1 (26-04-2024)
Laura Bubba, Kimberley S M Benschop, Soile Blomqvist, Erwin Duizer, Javier Martin, et al.. Wastewater Surveillance in Europe for Non-Polio Enteroviruses and Beyond. Microorganisms, 2023, 11 (10), pp.2496. ⟨10.3390/microorganisms11102496⟩. ⟨hal-04560128⟩
0 Consultations
0 Téléchargements
