Palladium-Polypyrrole Nanocomposites (Pd@PPy) Efficiently Promoting Pyrroles and Imidazoles Direct C-H Functionalization with Bromoarenes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SYNLETT Année : 2016
Palladium–polypyrrole nanocomposites (Pd@PPy) with unique combination of high palladium dispersion (nanoparticle size 2.4 nm) and high palladium content (35 wt%) are efficient catalysts for the selective arylation of substituted pyrroles and imidazoles with either activated or deactivated aryl bromides. The performances of the recoverable supported palladium catalyst matches the best performances of homogeneous systems based on Pd(OAc)$_2$ at 0.5–0.2 mol%, and largely overwhelm the classical Pd/C catalyst.
HAL_Version Synlett_2016.pdf (652.6 Ko) Télécharger le fichier
hal-04563426 , version 1 (02-05-2024)
Pierre Bizouard, Christelle Testa, Veronika Zinovyeva, Julien Roger, Jean-Cyrille Hierso. Palladium-Polypyrrole Nanocomposites (Pd@PPy) Efficiently Promoting Pyrroles and Imidazoles Direct C-H Functionalization with Bromoarenes. SYNLETT, 2016, 27 (08), pp.1227-1231. ⟨10.1055/s-0035-1561113⟩. ⟨hal-04563426⟩
4 Consultations
0 Téléchargements
