Relative Pollen Productivity Estimates for Mediterranean Plant Taxa: A New Study Region in Turkey
This study estimates relative pollen productivity (RPP) for plant taxa from Southern Anatolia, an important region in the Mediterranean with a long history of human settlements. RPP estimates are required for quantitative pollen-based reconstruction of past land cover modelling. The application of the reconstruction by the REVEALS model in the Mediterranean basin is constrained due to the scarcity of the RPP values specific to the region. To better understand the relationship between vegetation cover and land use in the Mediterranean area, the present study aims to provide a set of RPPs for Turkey and the Mediterranean region. The study area centres around Gölhisar Lake in southwestern Turkey. Modern pollen data are collected from moss pollsters from 21 sites together with vegetation surveys. RPP estimates for the main taxa characteristic of the Mediterranean region are obtained (referenced to evergreen Quercus t.) using the extended R-value (ERV) model through the analysis of modern pollen assemblages. The most reliable results are acquired with the ERV sub-model 2 and Prentice’s taxon-specific method (using a Gaussian plume dispersal model) to distance-weighted vegetation data, corresponding to a Relative Source Area of Pollen (RSAP) value of 102 m. RPPs of dominant taxa in the study area are obtained for Quercus coccifera/Fagaceae (1 ± 0), Juniperus/Cupressaceae (0.279 ± 0.001), Fabaceae (0.008 ± 0.000), Pinus/Pinaceae (5.782 ± 0.011), and Poaceae (0.112 ± 0.001) and are comparable with other RPPs obtained in the Mediterranean region.
Relative_Pollen_Productivity_Estimates_for_Mediter FLORENCE MAZIER 2024.pdf (5.03 Mo)
Télécharger le fichier
Origin : Publisher files allowed on an open archive
