Padico: A Component-Based Software Infrastructure for Grid Computing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
This paper describes work in progress to develop a component-based software infrastructure, called Padico, for computational grids based on the CORBA Component Model from the OMG. The objective of Padico is to offer a component model targeting multi-physics simulations or any applications that require the coupling of several codes (simulation or visualization) within a high-performance environment. This paper addresses mainly two issues we identified as important for a grid-aware component model. The first issue deals with the encapsulation of parallel codes into components. We propose an extension to the CORBA component model called \gridccm. The second issue addresses the problem of the communication between components within a computational grid. We propose a portable runtime, called PadicoTM, able to efficiently support communication in a heterogeneous networking environment.
DenPerPriRib03IPDPS.pdf (94.94 Ko) Télécharger le fichier
inria-00000134 , version 1 (24-06-2005)
  • HAL Id : inria-00000134 , version 1
Alexandre Denis, Christian Pérez, Thierry Priol, André Ribes. Padico: A Component-Based Software Infrastructure for Grid Computing. 17th International Parallel and Distributed Processing Symposium (IPDPS 2003), Apr 2003, Nice/France, France. ⟨inria-00000134⟩
411 Consultations
240 Téléchargements
