Low Density Parity Check (LDPC) Staircase and Triangle Forward Error Correction (FEC) Schemes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autre Publication Année : 2006
This document describes two Fully-Specified FEC Schemes, LDPC-Staircase and LDPC-Triangle, and their application to the reliable delivery of objects on packet erasure channels. These systematic FEC codes belong to the well known class of ``Low Density Parity Check'' (LDPC) codes, and are large block FEC codes in these sense of RFC3453.
draft-ietf-rmt-bb-fec-ldpc-00.pdf (113.31 Ko) Télécharger le fichier
inria-00000147 , version 1 (06-07-2005)
inria-00000147 , version 2 (19-01-2006)
inria-00000147 , version 3 (01-03-2006)
inria-00000147 , version 4 (21-06-2006)
inria-00000147 , version 5 (22-12-2006)
inria-00000147 , version 6 (19-07-2007)
  • HAL Id : inria-00000147 , version 4
Vincent Roca, Christoph Neumann, David Furodet. Low Density Parity Check (LDPC) Staircase and Triangle Forward Error Correction (FEC) Schemes. 2006. ⟨inria-00000147v4⟩
520 Consultations
508 Téléchargements
