An efficient discretisation scheme for one dimensional SDEs with a diffusion coefficient function of the form |x|^a, a in [1/2,1) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2004
Mireille Bossy
In this paper, we study the rate of convergence of a symmetrized version of the classical Euler scheme, applied to the discretisation of the solution of a stochastic differential equation with a diffusion coefficient function of the form |x|^a, a in [1/2,1). For smooth test functions, we show that the weak error is of order one as for the classical Euler scheme. More over, the symmetrized version is very easy to simulate on a computer.
RR-5396.pdf (403.21 Ko) Télécharger le fichier
inria-00000177 , version 1 (22-07-2005)
inria-00000177 , version 2 (30-05-2006)
inria-00000177 , version 3 (31-05-2006)
inria-00000177 , version 4 (23-07-2007)
  • HAL Id : inria-00000177 , version 2
Mireille Bossy, Awa Diop. An efficient discretisation scheme for one dimensional SDEs with a diffusion coefficient function of the form |x|^a, a in [1/2,1). [Research Report] 5396, 2004, 48 p. ⟨inria-00000177v2⟩
Collections
INRIA-RRRT
497 Consultations
1270 Téléchargements
