Dynamic Neural Field with Local Inhibition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Biological Cybernetics (Modeling) Année : 2006
Nicolas P. Rougier
A lateral-inhibition type neural field model with restricted connections is presented here and represents an experimental extension of the Continuum Neural Field Theory (CNFT) by suppression of the global inhibition. A modified CNFT equation is introduced and allows for a locally defined inhibition to spatially expand within the network and results in a global competition extending far beyond the range of local connections by virtue of diffusion of inhibition. The resulting model is able to attend to a moving stimulus in the presence of a very high level of noise, several distractors or a mixture of both.
BiologicalCybernetics.pdf (14.9 Mo) Télécharger le fichier
inria-00000244 , version 1 (16-09-2005)
Nicolas P. Rougier. Dynamic Neural Field with Local Inhibition. Biological Cybernetics (Modeling), 2006, 94 (3), pp.169-179. ⟨10.1007/s00422-005-0034-8⟩. ⟨inria-00000244⟩
174 Consultations
358 Téléchargements
