Component Reuse in B Using ACL2 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
We present a new methodology that permits to reuse an existing hardware component that has not been developed within the B framework while maintaining a correct design flow. It consists of writing a specification of the component in B and proving that the VHDL description of the component implements the specification using the ACL2 system. This paper focuses on the translation of the B specification into ACL2.
34550281.pdf (223.2 Ko) Télécharger le fichier
inria-00000755 , version 1 (16-11-2005)
Yann Zimmermann, Diana Toma. Component Reuse in B Using ACL2. ZB Formal Specification and Development in Z and B - 4th International Conference of B and Z Users - ZB 2005, Apr 2005, University of Surrey, Guildford, UK, pp.280-299, ⟨10.1007/b135596⟩. ⟨inria-00000755⟩
320 Consultations
462 Téléchargements
