A Flexible Structured-based Representation for XML Document Mining - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
This paper reports on the INRIA group's approach to XML mining while participating in the INEX XML Mining track 2005. We use a flexible representation of XML documents that allows taking into account the structure only or both the structure and content. Our approach consists of representing XML documents by a set of their sub-paths, defined according to some criteria (length, root beginning, leaf ending). By considering those sub-paths as words, we can use standard methods for vocabulary reduction, and simple clustering methods such as K-means that scale well. We actually use an implementation of the clustering algorithm known as "dynamic clouds" that can work with distinct groups of independent variables. This is necessary in our model since embedded sub-paths are not independent.
INEXpaper.pdf (215.49 Ko) Télécharger le fichier
inria-00000839 , version 1 (23-11-2005)
inria-00000839 , version 2 (05-07-2006)
Anne-Marie Vercoustre, Mounir Fegas, Saba Gul, Yves Lechevallier. A Flexible Structured-based Representation for XML Document Mining. The Fourth International Workshop of the Initiative for the Evaluation of XML Retrieval (INEX 2005), Nov 2005, Schloss Dagstuhl, Germany, pp. 443 - 457, ⟨10.1007/11766278_34⟩. ⟨inria-00000839v1⟩
149 Consultations
374 Téléchargements
