Large-scale Deployment in P2P Experiments Using the JXTA Distributed Framework - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2004
The interesting properties of P2P systems (high availability despite peer volatility, support for heterogeneous architectures, high scalability, etc.) make them attractive for distributed computing. However, conducting large-scale experiments with these systems arises as a major challenge. Simulation allows only to partially model the behavior of P2P prototypes. Experiments on real testbeds encounter serious difficulty with large-scale deployment and control} of peers. This paper shows how an optimized version of the JXTA Distributed Framework (JDF) can help deploying, configuring and controlling P2P experiments. We report on our experience in the context of our JuxMem JXTA-based grid data sharing service for various configurations.
Mots clés
AntBouJanMon-EuroPar2004.pdf (74.46 Ko) Télécharger le fichier
inria-00000977 , version 1 (09-01-2006)
  • HAL Id : inria-00000977 , version 1
Mathieu Jan, Gabriel Antoniu, Luc Bougé, Sébastien Monnet. Large-scale Deployment in P2P Experiments Using the JXTA Distributed Framework. Euro-Par 2004: Parallel Processing, Aug 2004, Pisa, Italy, Italy. pp.1038-1047. ⟨inria-00000977⟩
197 Consultations
247 Téléchargements
