Fast algorithms for computing the eigenvalue in the Schoof-Elkies-Atkin algorithm - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
The Schoof-Elkies-Atkin algorithm is the only known method for counting the number of points of an elliptic curve defined over a finite field of large characteristic. Several practical and asymptotical improvements for the phase called eigenvalue computation are proposed.
issac06.pdf (126.32 Ko) Télécharger le fichier
inria-00001009 , version 1 (13-01-2006)
Pierrick Gaudry, François Morain. Fast algorithms for computing the eigenvalue in the Schoof-Elkies-Atkin algorithm. ISSAC '06: Proceedings of the 2006 international symposium on symbolic and algebraic computation, Jul 2006, Genoa, Italy, pp.109 - 115, ⟨10.1145/1145768.1145791⟩. ⟨inria-00001009⟩
1811 Consultations
687 Téléchargements
