Reed-Solomon Forward Error Correction (FEC) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autre Publication Année : 2006
This document describes a Fully-Specified FEC scheme for the Reed-Solomon forward error correction code and its application to reliable delivery of data objects on the packet erasure channel. The Reed-Solomon codes belong to the class of Maximum Distance Separable (MDS) codes, i.e, they enable a receiver to recover the k source symbols from any set of k received symbols. The implementation described here is compatible with the IPR-free implementation from Luigi Rizzo.
draft-rmt-bb-fec-rs-00.pdf (58.23 Ko) Télécharger le fichier
inria-00001136 , version 1 (01-03-2006)
inria-00001136 , version 2 (22-12-2006)
inria-00001136 , version 3 (19-07-2007)
  • HAL Id : inria-00001136 , version 2
Jérôme Lacan, Vincent Roca, Sami Peltotalo, Jani Peltotalo. Reed-Solomon Forward Error Correction (FEC). 2006. ⟨inria-00001136v2⟩
142 Consultations
156 Téléchargements
