Formal Islands
Motivated by the proliferation and usefulness of Domain Specific Languages as well as the demand in enriching well established languages by high level capabilities like pattern matching or strategic rewriting, we introduce the \emph{Formal Islands} framework. The main idea consists to integrate, in existing programs, formally defined parts called Islands, on which proofs and tests can be meaningfully developed. Then, Formal Islands could be safely dissolved into their hosting language to be transparently integrated in the existing user environment. The paper presents this generic framework and shows that the properties valid on the formal islands are also valid on the corresponding dissolved host codes. Formal Islands can be used as a general methodology to develop new DSL and we show that language extensions like sqlj ---embedding sql capabilities in Java ---, or Tom ---a Java language extension allowing for pattern matching and rewriting---are indeed Islands and they can therefore be used for formal software developments.
Informatique et langage [cs.CL]
