Transformation of B Specifications into UML Class Diagrams and State Machines - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2006
We propose a rule-based approach for transforming B abstract machines into UML diagrams. We believe that important insight into the structure underlying a B model can be gained by representing it in UML, for example in order to explain the model to stakeholders that are not experts in the B formalism. We focus on the generation of class diagram and state machines. Our approach does not prescribe a mechanic algorithm for translation, giving the modeler choices to adapt the resulting UML models as appropriate.
final.pdf (617.4 Ko) Télécharger le fichier
Dates and versions
inria-00001269 , version 1 (27-04-2006)
Identifiers
  • HAL Id : inria-00001269 , version 1
Cite
Houda Fekih, Leila Jemni Ben Ayed, Stephan Merz. Transformation of B Specifications into UML Class Diagrams and State Machines. 21st Annual ACM Symposium on Applied Computing - SAC 2006, Apr 2006, Dijon, France, pp.1840-1844. ⟨inria-00001269⟩
204 View
426 Download
Share
