Proving formally the implementation of an efficient gcd algorithm for polynomials - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
Assia Mahboubi
We describe here a formal proof in the Coq system of the structure theorem for subresultants, which allows to prove formally the correction of our implementation of the subresultant algorithm. Up to our knowledge, it is the first mechanized proof of this result.
SousRes.pdf (159.24 Ko) Télécharger le fichier
inria-00001270 , version 1 (28-04-2006)
  • HAL Id : inria-00001270 , version 1
Assia Mahboubi. Proving formally the implementation of an efficient gcd algorithm for polynomials. Automated Reasoning, Third International Joint Conference, IJCAR 2006, Aug 2006, Seattle, WA, United States. pp.438-452. ⟨inria-00001270⟩
Collections
INRIA INRIA2
115 Consultations
458 Téléchargements
