An Implementation of the Shooting Algorithm for Solving Optimal Control Problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2000
We describe the software OCS-SA for solving % two points boundary value problems (TPBVP) and optimal control problems. The method is essentially an implementation of Newton's method applied to an associated two points boundary value problems (TPBVP). The latter is reduced to a finite dimensional problem through the use of a shooting function. We use the MAPLE and SCILAB softwares. The differential equations to be solved by the shooting algorithm are automatically generated, as well as a latex report, including description of the problem and numerical results.
RT-0240.pdf (284.03 Ko) Télécharger le fichier
inria-00069932 , version 1 (19-05-2006)
  • HAL Id : inria-00069932 , version 1
J. Frederic Bonnans, S. Maurin. An Implementation of the Shooting Algorithm for Solving Optimal Control Problems. [Research Report] RT-0240, INRIA. 2000, pp.24. ⟨inria-00069932⟩
308 Consultations
1116 Téléchargements
