MODE-PP HTML: A GDMO/GRM to HTML Translator -Release 1.0-Reference Manual
MODE-PP HTML (MODE Pretty-Printing HyperText Markup Language) is a module which generates a hypertext representation of GRM (General Relationship Model) and GDMO (Guidelines for the Definition of Managed Objects) specifications. The tool generates for a given specification the whole architecture required for the navigation facility within the specifications in an Intranet. MODE-PP HTML is part of the MODERES (Managed Object Development Environment by RESEDAS) toolkit which is developed for facilitating the use of GDMO and GRM as well as integrating the use of Formal Description Techniques in an environment for building Management applications. MODE-PP HTML is built on top of MODE-FE and is provided as a library. This document is the reference manual for release 1.0 of the MODE-PP HTML library and its API.
