Feedback stabilization for a chemostat with delayed output - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
In this paper we consider a problem of asymptotic stabilization for a chemostat, by using a feedback control law and considering a delay $\tau>0$ on its output. The presence of these delays on the outputs makes more difficult to achieve our asymptotic stabilization objectives. We build a family of feedback control laws (using the dilution rate as control variable) obtaining sufficient conditions for asymptotic stabilization, given by upper bounds for the delay (which are dependent of the feedback control law). Using some reduction techniques we show that the control problem becomes equivalent to obtain global stability conditions for the zero solution of the scalar differential delay equation: $$ \dotu(t)=-G(u(t))+F(u(t-\tau)). $$
Autre [cs.OH]
RR-5844.pdf (333.47 Ko) Télécharger le fichier
inria-00070182 , version 1 (19-05-2006)
  • HAL Id : inria-00070182 , version 1
Gonzalo Robledo. Feedback stabilization for a chemostat with delayed output. [Research Report] RR-5844, INRIA. 2006, pp.30. ⟨inria-00070182⟩
248 Consultations
237 Téléchargements
