No-gap Second-order Optimality Conditions for Optimal Control Problems with a Single State Constraint and Control - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
The paper deals with optimal control problems with only one control variable and one state constraint, of arbitrary order. We consider the case of finitely many boundary arcs and touch times. We obtain a no-gap theory of second-order conditions, allowing to characterize second-order quadratic growth.
RR-5837.pdf (433.45 Ko) Télécharger le fichier
inria-00070189 , version 1 (19-05-2006)
  • HAL Id : inria-00070189 , version 1
J. Frederic Bonnans, Audrey Hermant. No-gap Second-order Optimality Conditions for Optimal Control Problems with a Single State Constraint and Control. [Research Report] RR-5837, INRIA. 2006, pp.30. ⟨inria-00070189⟩
141 Consultations
238 Téléchargements
