Optimal succinct representation of planar maps - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
This paper addresses the problem of representing the connectivity information of geometric objects using as little memory as possible. As opposed to raw compression issues, the focus is here on designing data structures that preserve the possibility of answering incidence queries in constant time. We propose in particular the first optimal representations for 3-connected planar graphs and triangulations, which are the most standard classes of graphs underlying meshes with spherical topology. Optimal means that these representations asymptotically match the respective entropy of the two classes, namely 2 bits per edge for 3-c planar graphs, and 1.62 bits per triangle or equivalently 3.24 bits per vertex for triangulations.
Autre [cs.OH]
RR-5803.pdf (479.27 Ko) Télécharger le fichier
inria-00070221 , version 1 (19-05-2006)
  • HAL Id : inria-00070221 , version 1
Luca Castelli Aleardi, Olivier Devillers, Gilles Schaeffer. Optimal succinct representation of planar maps. [Research Report] RR-5803, INRIA. 2006, pp.26. ⟨inria-00070221⟩
269 Consultations
146 Téléchargements
