Almost Perfect Nonlinear functions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2005
Anne Canteaut
Yann Laigle-Chapuy
  • Fonction : Auteur
  • PersonId : 833446
We investigate some open problems on Almost Perfect Nonlinear (APN) functions over a finite field of characteristic $2$. We provide new characterizations of APN functions and of APN permutations by means of their component functions. We generalize some results of Nyberg (1994) and strengthen a conjecture on the upper bound of nonlinearity of APN functions. We also focus on the case of quadratic functions. We contribute to the current works on APN quadratic functions, by proving that a large class of quadratic functions cannot be APN.
RR-5774.pdf (390.32 Ko) Télécharger le fichier
inria-00070246 , version 1 (19-05-2006)
  • HAL Id : inria-00070246 , version 1
Thierry Pierre Berger, Anne Canteaut, Pascale Charpin, Yann Laigle-Chapuy. Almost Perfect Nonlinear functions. [Research Report] RR-5774, INRIA. 2005, pp.28. ⟨inria-00070246⟩
227 Consultations
1195 Téléchargements
