Dassflow :a Direct and Adjoint model for 2D Shallow Water flows - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2005
François-Xavier Le Dimet
  • Fonction : Auteur
Youssef Loukili
  • Fonction : Auteur
Jerome Monnier
The Dassflow software is designed to solve the bidimensional Shallow Water equations used for the numerical modeling of river hydraulics flows. It was written to carry out variational data assimilation experiments. Based on a finite volume discretization of the Shallow Water equations, the code is written in Fortran 90. The adjoint code necessary to compute the partial derivatives of a cost function of the state variables w.r.t. the control variables of the model was developed using the automatic differentiation tool Tapenade. We present the considered equations, the theoretical bases of variational data assimilation, the numerical scheme used for solving the equations as well as the implementation of the adjoint code. Finally, we present twin experiments of data assimilation performed with Dassflow.
RR-5756.pdf (343.8 Ko) Télécharger le fichier
inria-00070264 , version 1 (19-05-2006)
  • HAL Id : inria-00070264 , version 1
Marc Honnorat, François-Xavier Le Dimet, Youssef Loukili, Jerome Monnier. Dassflow :a Direct and Adjoint model for 2D Shallow Water flows. RR-5756, INRIA. 2005, pp.21. ⟨inria-00070264⟩
614 Consultations
1071 Téléchargements
